Tilt Wall Panels
Last Post 06 Jul 2009 11:25 AM by Jerry Coombs. 3 Replies.
02 Jul 2009 07:00 PM
Insuldeckflorida,
Where in the wall is the insulation - inside, outside, middle?
What type of insulation is in the panels -  EPS, XPS, Polyurethane?
What is the maximum length for a 10' tall panel?
How thick are the panels for a residence?
How are the panels connected and sealed?
Is the panel formed on site or factory?
Would the Tilt Wall Panel system be available around Orlando FL?
insuldeckfloridaUser is Offline
03 Jul 2009 08:41 AM
alton,
give me a call so we can talk...
772 201 6100
peter
03 Jul 2009 12:07 PM
From a quick read, these are like one sided ICFs. Ie, foam on the inside but exposed concrete on the outside. Poured on site, interior side down and then titled up.
Jerry D. Coombs, PEUser is Offline
Insulation can go inside or outside, and w/ stiffening ribs can go very high. Widths are governed by several things, so how long do you want them? 30 ft max is a good rule, and not more than 50 ft or you'll likely get cracking probs. Actually, insuldeckflorida is the best place to get information.
<br>You can have with quality; You can have it fast; You can have it cheap.
Pick any two.
People Online People Online: Visitors Visitors: 250 Members Members: 0 Total Total: 250
