Posted By bbicf on 08/05/2009 9:29 PM
Thanks for the reply, with removing the screws later and using them to screw in the nailing flange how much bigger did you make the buck. I remeber having to make them 3 inches bigger when i did it beforebut surely this way would eliminate that.
The inside dimensions of the window bucks were the same as the rough opening specified by Andersen for their windows, usually taken to the closest 1/4 or 1/2 inch. Generally, the RO was about 3/4 to 1" wider and, IIRC, about 1"+ taller, than the frame of the window. The idea was to have just enough space to get the windows plumb, and have nearby windows line up vertically. If the windows were several feet apart I didn't get carried away getting them aligned vertically. I did end up with some ROs that were a little higher than they should have been. Twisted and crooked 2xs contributed. I located the ROs vertically by measuring from the floor, not by referencing to the courses of the blocks.
We discovered fairly quickly that, even though Andersen makes high quality windows, most of the windows were not perfectly square. That meant that one side of the frame would be off plumb or off level by maybe 1/16" or 1/8". You just have to square up the window the best you can and figure out where to put the misalignment so it will be the least visually apparent.
A good axiom to keep in mind when it comes to shooting for cosmetic perfection in construction. "A fool will never see the mistake, and a wise man will know better than to say anything!"
