Shallow frost protected foundation
Last Post 22 Aug 2009 12:33 PM by eric monkman. 8 Replies.
WI HANKUser is Offline
07 Aug 2009 08:12 PM
I am building a detached workshop/Garage, I am familiar with SFPF (slab and/or Grade beams). I have built 3 homes using Shallow Frost Protected Foudations w/radiant In-floor heat, but stick built.  I want to build my garage w/12' walls with 6" ICF (Fox Block) I would typically go 8" deep, 12" wide then 45 degree my way up to my 4" slab thickness.  I have been told that  I should go 12" deep to handle the additional weight of the ICF walls.  I am building in sandy soil, putting in Radiant In-Floor heat, and the building site is located here in Western Wisconsin.  Have any of you built a similar project, or does anyone have any suggestions?  FYI-I contacted my local building inspector and he told me that there is not a code that dictates how deep I need my SFPF to be (Detached garage) as long as the concrete under the ICF can handle the load.  I will also be using 2" high density insulation.  Thank you, WI Hank
07 Aug 2009 10:35 PM
I've always seen a minimum of 12" depth in references. But are you asking about footing thickness/strength?  As I recall, that is well specified by code.
07 Aug 2009 10:42 PM
Just wanted to know if a 12" depth would be strong enough for  6" ICF 12 walls, or should the depth be more than 12".  Thanks
07 Aug 2009 11:04 PM
I am no expert, but as I read it, that is more than enough footer thickness for the footing width and wall thickness you have selected.
11 Aug 2009 06:03 PM
Thanks jonr, my building permit should be anyday.  My plan is to from the perimeter of my SFPF - slabe on grade with a 2 x 12 w/2" foam on the sides and bottom of the footing, that will give me a net depth of a 9 1/4 " footing.
arkie6User is Offline
12 Aug 2009 06:23 PM
Posted By WI HANK on 08/11/2009 6:03 PM
Have you considering using Fast Foot instead of that 2x12 for your footing forms?
Fast Foot link
12 Aug 2009 07:23 PM
Arkie6, thanks for the link.  I checked it out, i'll have to do some more thinking. I can see how it would eliminate being so fussy with the bottom footing.
woulfccUser is Offline
18 Aug 2009 11:09 PM
You might try the first row of forms wet set with your rebar wet setin the slab. Just think how the floor and wall can be poured as a beam.
eric monkmanUser is Offline
Hank, have you run this by a P Eng ?
The selection and placement of steel re-inforcing plays as big a role as footing depth in your case.
People Online People Online: Visitors Visitors: 311 Members Members: 0 Total Total: 311
