Left Over Foam - what to do with?
Last Post 13 Oct 2009 09:20 AM by thagreen. 14 Replies.
newbiejohnUser is Offline
10 Sep 2009 05:15 PM
Put up a TF ICF home and basement and have alot of left over foam that we had to cut off or had to trim off the edges. Is there any usefull place to place this foam to help with insulation that would save it from the landfill?  Would it really help by dumping it all in the attic ?
ClarkUser is Offline
11 Sep 2009 10:38 AM
I had quite a few full length foam TF panels left after all the walls were poured. I used them to insulate a section of the garage floor. The nice thing about insulating the garage floor is that in summer, the floor doesn't reach dewpoint, so it doesn't sweat.
11 Sep 2009 01:34 PM
Great idea, i dont have a whole lot of full pieces, but LOTS of cut pieces, wouldnt hurt to put it all below the floor would it ?
11 Sep 2009 07:18 PM
If you don't want to spend the money to insulate the whole garage floor, you can simply insulate around the periphery where most of the heat loss will occur. Think along the lines of how a slab on grade foundation is insulated.
rykertestUser is Offline
11 Sep 2009 08:51 PM
I think clark is thinking right here. The perimiter should be the focus. If you choose not to do that it can be recycled but you did pay for it so might as well use it. :)
14 Sep 2009 12:37 PM
I think once you take into account the foam crates that the foam was stacked on, ill have enough to do almost the entire garage using the pieces we had to trim down, left overs and cut ends and what not.
14 Sep 2009 08:39 PM
Composite ICFs use recycled EPS. And near me an EPS moulder grinds it and sells it as a pourable insulation, mostly for CMUs.
15 Sep 2009 04:11 PM
Posted By newbiejohn on 09/14/2009 12:37 PM
John, keep in mind that the foam pallets that the TF System panels were shipped on are made of a low density EPS.  Could experience some compression.  I'd use it around the periphery and be sure to tie the garage floor to the foundation (stem wall) with rebar dowels.
medelpadconstUser is Offline
16 Sep 2009 07:40 AM
I place any leftover scrap flat on top of the ceiling drywall and blow cellulose over it . This will take up some of the space and keep it out of the dump.
19 Sep 2009 08:50 AM
Posted By newbiejohn on 09/10/2009 5:15 PM
If ther are no recyclers in the area, post it on Craig's List as free - can be used for crafts or insulation.....and it will disapear
22 Sep 2009 08:48 PM
Central Florida now has an EPS recycler
http://www.recyclemystyrofoam.com/index.php
06 Oct 2009 03:29 PM
I think there is misconceptions regarding plastic, including EPS. The landfills around here would rather get plastic than paper or cardboard. Which didn't make much sense to me but my uncle owns a roll-off construction dumpster company. I asked him why it says "no cardboard" on the side of dumpsters, he said the landfills don't want it. I am also told that is why shingle bundles come in plastic and no longer paper wrapping.
06 Oct 2009 04:00 PM
Shingles like groceries come in plastic because its cheaper and they don't fall apart when they get wet.
But there is a recycle market for EPS reqround is used in some OSB SIPs, also used for packing. None need to go to a landfill before we had a recycle source we would atvertise on Craig's list as free.
I have had teachers come and take for crafts and frugal DIY's re-use for insulation
MDiverUser is Offline
07 Oct 2009 02:05 PM
in a cold climate, you can insulation to your footing
thagreenUser is Offline
Personaly I would go with the floor insulation option. Insulating the ceilings with it will leave cracks and therefor compromising the seal created to eliminate heat loss. Also, most icf's have same if not higher density as floor insulation so greater settlement should not be of concern.
Cheers!
People Online People Online: Visitors Visitors: 202 Members Members: 0 Total Total: 202
