Reliable ICF builders near Fargo, ND or Watertown, SD and Sisseton, SD
Last Post 19 Jan 2010 09:47 AM by tdbuilder. 6 Replies.
GolfCoachUser is Offline
14 Nov 2009 07:06 PM
We are building a new house hopefully the spring to summer of 2010 and would like any recommendations of experienced, reliable, and economically priced ICF contractors / builders that service the Northeastern counties of South Dakota near Sisseton, SD (possibly out of Watertown, SD or Fargo, ND). Thanks, Bill
"I'm in the Hole"
slowroadsterUser is Offline
14 Nov 2009 08:03 PM
Don Riley in Watertown did my ICF basement a couple of years ago, did a great job!
14 Nov 2009 08:43 PM
What size and style house did you build? Was it in Watertown or the surrounding area? We were also curious appx. price for sf they charged for the style of house you built. Our house plan is about 1268 sf on the main living floor and the walk out unfinished basement would be the same size. Also, there is a 24x 33 attached unfinished garage. Did you use the ICFs on just the basement walls or the above ground walls too? Did he do the entire home build or just the icfs?
"I'm in the Hole"
14 Nov 2009 10:12 PM
We built a 1 1/2 story Cape Cod style home in Watertown. Don did the basement walls and the garage foundation with Liteform ICF. He also did my flat work. The rest of the house is stick built with spray foam insulation. You can reach Don at (605) 880-2072.
SpencerUser is Offline
16 Nov 2009 04:58 PM
David De LAir is from Detroit Lakes MN. Call him at 218-847-5222 or email at [email protected]
Cattail BillUser is Offline
16 Jan 2010 04:24 PM
Moen construction in Fargo they have done many homes in the Fargo area and they go out about 150 miles for jobs. They are also a turn key builder so you can get the complete job done if you wantincluding those awful sticks!!!
tdbuilderUser is Offline
Golfcoach,
Another guy you should get a hold of is PDT Construction in Elbow Lake, MN. Dean is a good guy and does 10-20 good sized ICF projects each year. His number is (218) 849-2214 if I rememeber correctly.
People Online People Online: Visitors Visitors: 173 Members Members: 0 Total Total: 173
