Re: Window Detail: I prefer to run the exterior ICF foam all the way up under the window -- without it the wood provides quite the thermal bridge (more so in the north-land -
). Overall, when you consider that one can polish and stain the sills and round the corners etc. etc. this approach works quite well.
You have to watch things quite carefully, depending on slump (as mentioned above by wes) -- doing windows this way is outside of the typical installation and requires significant attention (and touch up) to the window sill(s) for an hour or more after the pour is complete. Regards.
