I would like to know if this makes sense or will work
I am installing the icf connect roof trusses for attaching the trusses to the top of my icf wall. I had a lift along on wall during foundation pour so that wall is 1 inch out of level.(i dont want any jibes about being out of level etc, i am, and will deal with it, ) My idea is that I will set my icf connect plates in place before concrete is set at the top of the wall. When I go to install my trusses I will take a laser around and set each truss at the right level, for the ones that are going to be raised off of concrete i will provide a metal shim so that it still bears on solid, and they will all be screwed in using bearing brackets with the icf system. I figure this may be the easiest way to level my trusses. does this sound reasonable. or does anyone have an easier suggestion. i thought about cutting into the foam at each truss location prior to pour so that all the connectors were at the right level, but figured the other way was easier. or i when i go to wet set them i could take a laser and set wet set them at level. any other suggestions.
thanks
