Posted By TexasICF on 01/20/2010 8:25 AM
A 10’ standard stud is 116 5/8” long or 3 3/8” shorter than one might logically expect.
Not that this makes all the sense in the world but then when you put down your bottom plate 1 ½ (2x material), add 116 5/8” standard “10 ft” stud” and a double top plate (for your interior walls) you will have a subfloor to ceiling joists height of 10’ 1 1/8” (this is 121 1/8”).
Thanks for the correction. I've only gone through the process once and forgot to add the ceiling drywall thickness and the gap at the bottom for flooring thickness.
