Electric in waffle grid type icf's.
Last Post 05 Feb 2010 11:33 AM by Buntly. 5 Replies.
BuntlyUser is Offline
01 Feb 2010 07:31 AM
I have a small job coming up in which I will be using waffle grid type icf. Does anyone have experience installing electical in this type of icf? I have always used flat wall systems. On flat wall systems, I always use metal boxes if the foam thickness is 2 1/4" or less and I use plastic boxed on icf's with a foam thickness of 2 1/2" or greater.  The boxes could obviously be mounted to the concrete anywhere on the wall with a tapcon. What happens in a screen grid type icf? It is unlikely you are going to find a flat spot anywhere in the wall to mount a box. I want to be able to mount boxes anywhere on the wall, I don't want to use the boxes with a flange and mount to the ties. Any input would be greatly appreciated.
Thanks!!
Bunt
tdamagedUser is Offline
02 Feb 2010 04:14 PM
On waffle grid blocks we normally use 4 x 4 x 1 1/2 side mount with 1/2" plaster ring for drywall. Those areas where the wires exceed the points of the box, we chip out the concrete for the required size box with a side mount. Electrical inspectors in our area frown upon tapconing boxes to the concrete.
02 Feb 2010 07:50 PM
We don't have to connect a box to concrete, so there is no difference. The glue is plenty to hold a box.
02 Feb 2010 07:59 PM
I have to deal with one inspector who demands there be a mechanical connection of the box to the concrete.
Bunt
05 Feb 2010 10:46 AM
Buntly, glue your inspector to the concrete. He'd prob then change his mind when he goes home w/out a shirt on.
He he he, I don't think he would find that too amusing. I might just have to give it a try though!
Bunt
People Online People Online: Visitors Visitors: 187 Members Members: 0 Total Total: 187
