While soil conditions, drainage, and location play an important role, nothing is more important than a dry basement or crawl space. I have used several of the peal and stick products and while they work in clean and dry working conditions - like in a lab, they don't always work that well in the real world. I've found they don't always stick that well to dusty forms or in special situations, especially where you have a brick ledge sloping out or where there is a transition from green concrete to icf - (a retaining wall for example). On one of my first jobs I had a rather expensive call-back where my peal and stick bituthane membrane had lost adhesion due to heat from direct sunlight allowing dirt and later water to breach the seal after backfilling. The best product I've found is a water based rubber membrane that can be either rolled, painted or sprayed to the desired thickness. This product in combination with a protective plasic membrane, a quality drain mat, along with proper tileing and gravel assures a dry foundation. There are several products out there that will do the job. Some of the better ones are also UV resistant. I've had good luck with a product from EPRO Services from Derby, Kansas. "
www.eproserv.com" This waterproofing along with TF systems ICF products has served me well. I'm from southeastern Illinois where soil conditions vary from sandy to gumboot-sticking clay and the weather is always an extreem.
