Dimensional questions about ICF
Last Post 28 Jun 2010 10:12 PM by Trooper4985. 7 Replies.
Trooper4985User is Offline
26 Jun 2010 10:14 PM
I'm in the planning stages of my 4 car garage with a little living space above it.  I've come up with a 70'X40' footprint with 14' ceiling for the garage level (2 post car lift).  From what I have found on this site, a 40' span for ICF flooring is pushing the limits.  Based on the floorplan below, I have 2 questions and I'm sure I will come up with more later.
1.)  How would you orient a support beam and vertical column?  I want to keep a minimum 7' clearance over the stairs so would a slightly offset (12'-14' from south wall) beam with a column between the 2nd and 3rd garage bay?  I'm not overly concerned with obstructions between the first 3 bays but nothing between the 3rd and 4th bay because of the lift I am installing (BendPak XPR-10ACX).
2.)  What is the maximum roof pitch (haven't decided on hip or gable yet) that you can accomplish with ICF?  The attic area will be used for nothing more than storage so roof height isn't a big deal.
1st Floor plan
2nd Floor plan
Exterior
27 Jun 2010 08:58 AM
You probably already know that you will need an engineer to review your plans and come up with the specs. But it is a good idea to know what they will likely look for so you don't have to redraw and submit it to the engineer again. That being said, post a sketch, because I don't get the picture. I am not an engineer, but...
1.) I have been told that ICF roof and floor forms, such as AmDeck, BuildDeck, Insuldeck and Lite-Deck, do not reasonable span more than 30'. I have a roof plan from a customer so only snow for a live load, spanning 32'7" and two engineers have said not good. I would like to try post tensioning, but the project is on hold and the post-tensioning institute does not respond. Maybe with post tensioning you could span 40'
for a 40' x 70' you could have one beam, down the middle the long way or two the short way for 23'4" spans. You could do a flush beam so it is no lower, or higher than the rest of the floor system. You would need columns.
2.) Do you mean maximum pitch of ICF walls on a gable end, if so there is no maximum, you could put a form on top of the ICF walls system to keep your concrete from flowing out.
If you mean maximum pitch of a concrete roof, there is no maximum, just a lot of prep work. Below 4/12 or maybe 6/12 I would use one of the aforementioned ICF roof forms and a stiff mix and anchored rebar to prevent sliding. Beyond that I would use ICF wall forms and pour in them.
27 Jun 2010 09:13 AM
This is a good roof thread
pjfUser is Offline
27 Jun 2010 10:16 AM
Look at Hambro, they can span the distance you require
Bruce FreyUser is Offline
27 Jun 2010 11:52 AM
Are you covering the entire space with the elevated slab? I assume you are interested in an ICF solution because you want an insulated slab over an unheated or partially heated garage. I think you will be happier if you do it column free.
At 40' span, regular reinforced concrete is not very efficient, although a post tensioned slab would be a good solution and provide a flat surface for easy insulating. While not rocket science, post tensioning expertise (and cost) varies greatly from region to region.
40' is no problem for bar joists and metal deck. I have no experience with Hamro, but it appears to be efficient becuase it creates a "composite" structure. Insulating will be a bit more difficult with any metal joist system.
Bruce
Bruce
27 Jun 2010 01:52 PM
Trooper4985,
Since you plan to have living space above be sure to question Hambro about excessive vibration with their system on such a long span.
If you want to clear span 40' then check out Metwood beams with camber.  Compare Metwood beams versus Gluelam and rediron beams.  Watch out for deflection in the non-cambered beams.  Although a beam with deflection may be safe, it makes the ceiling appear to be sagging.
27 Jun 2010 03:59 PM
Metwood and Hambro look good, haven't used them, but have talked to Metwood and I was impressed. the insulation and attachment of the ICFs for floors are an advantage. If you have in-floor heat insulation is needed.
I fixed the problem with the floor span... I expanded a few feet each way (72X44 to multiples of 4 for less waste) and added rooms for the utiliies, storage, brewing, hunting and pantry.  The concrete is going to be supplied by a guy I work with so I'm getting it at cost.
Thanks for the input.
