thin brick fire resistance
Last Post 20 Sep 2010 08:10 PM by ICFconstruction. 8 Replies.
HardrockcorpUser is Offline
14 Sep 2010 10:53 AM
I'd like to apply thin brick veneer directly to the interior side of Logix ICF using lath and mortar. Is sheetrock still necessary for fire resistance? Thanks.
radiantbarrierUser is Offline
14 Sep 2010 11:09 AM
PlasterMax-ICF is the world's first fire rating coating replacing drywall over ICF. It is an abuse resistant eco- friendly cementitious building material that is used in residential, comercial, schools, hotels, and more. FMI see www.Barrett-inc.com or call us 877 9904 8424
BrucePolycreteUser is Offline
14 Sep 2010 11:38 AM
PlasterMax is great stuff. We're looking forward to using it on some school projects.
14 Sep 2010 11:40 AM
Is PlasterMax used as a mortar for thin brick?
Jerry D. Coombs, PEUser is Offline
17 Sep 2010 05:01 PM
Contact the manufacturer of the veneer. They may have a system that has the required fire rating. It will have to have been tested and have an ICC report.
<br>You can have with quality; You can have it fast; You can have it cheap.
Pick any two.
17 Sep 2010 05:06 PM
You can purchase thin brick panelized on cement board panels, and I believe they are fire rated.
20 Sep 2010 07:11 AM
Of course the scratch coat and thin brick veneer would be a 15 minute fire barrier. The problem is unless someone paid big money for the testing your local building official may not let you use it.
20 Sep 2010 10:33 AM
Thanks Brad, that's what I was thinking. I was hoping there might be some sort of prescriptive path or established fire resistance standard for mortar + brick.
What I will do on my own house, is not ask if what I do meets the requirement for the fire-rating, I will just do what I want. If you ask, they will take the most extreme position.
People Online People Online: Visitors Visitors: 273 Members Members: 0 Total Total: 273
