Hardrockcorp
| 14 Sep 2010 10:53 AM |
I'd like to apply thin brick veneer directly to the interior side of Logix ICF using lath and mortar.
Is sheetrock still necessary for fire resistance?
Thanks. |
radiantbarrier
| 14 Sep 2010 11:09 AM |
PlasterMax-ICF is the world's first fire rating coating replacing drywall over ICF. It is an abuse resistant eco- friendly cementitious building material that is used in residential, comercial, schools, hotels, and more. FMI see www.Barrett-inc.com or call us 877 9904 8424 |
BrucePolycrete
| 14 Sep 2010 11:38 AM |
PlasterMax is great stuff. We're looking forward to using it on some school projects. |
Hardrockcorp
| 14 Sep 2010 11:40 AM |
Is PlasterMax used as a mortar for thin brick? |
Jerry D. Coombs, PE
| 17 Sep 2010 05:01 PM |
Contact the manufacturer of the veneer. They may have a system that has the required fire rating. It will have to have been tested and have an ICC report. |
<br>You can have with quality; You can have it fast; You can have it cheap. Pick any two. |
BrucePolycrete
| 17 Sep 2010 05:06 PM |
You can purchase thin brick panelized on cement board panels, and I believe they are fire rated. |
ICFconstruction
| 20 Sep 2010 07:11 AM |
Of course the scratch coat and thin brick veneer would be a 15 minute fire barrier. The problem is unless someone paid big money for the testing your local building official may not let you use it. |
Hardrockcorp
| 20 Sep 2010 10:33 AM |
Thanks Brad, that's what I was thinking. I was hoping there might be some sort of prescriptive path or established fire resistance standard for mortar + brick. |
ICFconstruction
| 20 Sep 2010 08:10 PM |
What I will do on my own house, is not ask if what I do meets the requirement for the fire-rating, I will just do what I want. If you ask, they will take the most extreme position. |
