window and door buck question
Last Post 29 Sep 2010 08:45 PM by ICFconstruction. 3 Replies.
scicfUser is Offline
28 Sep 2010 10:55 PM
I've decided to try plywood bucks on an upcoming build. Just wondering if the plywood (3/4) needs to be doubled on the sides to give more meat for attachment. I've always used treated dimensional and like the idea of having less movement after the pour. I don't see any problems with window bucks, but it doesn't seem to be quite enough for doors. Any thoughts?
TexasICFUser is Offline
29 Sep 2010 07:10 AM
Hugh,
I would double the 3/4 (treated?). You can also use non-treated even 2x12 etc. with protection (e.g. Tyvek). Sometimes this performs better than the treated. Also you might consider: 1) Rim Board -- expensive but can simplify things for 8" (13 1/4") and up no ripping and double bucking if you will. 2) You might also consider going back to how you've bucked all along and adding extra of 5 or 6" maze nails (twisted to grab concrete) and leaving your internal bracing in for several days to allow the concrete (and wood) to cure a bit. 3) You might consider V-buck as well. Regards.
thagreenUser is Offline
29 Sep 2010 05:00 PM
Doubling the 3/4 ply ? Doesn't that bring you back to 2x12??
My favorite buck, for doors is 3/4" GT plywood attached to a 2x6 ripped at 22.5 degrees, and turned so the concrete gets behind the angle cut to hold it on. If that makes sense. That gives you 2.25" to attach trim and stuff.
On my own house we are trying three other methods too. No wood, 2x12 as finished buck for overhead doors, and spf 2x8 that do not go to the exterior.
People Online People Online: Visitors Visitors: 278 Members Members: 0 Total Total: 278
