ICFs for prisons
Last Post 21 Jan 2011 01:23 PM by radiantbarrier. 8 Replies.
BrucePolycreteUser is Offline
14 Jan 2011 04:46 PM
Does anyone know if any ICFs have gone through the ASTM 2322-03 “Standard Test Method for Physical Assault on Vertical Fixed Barriers for Detention and Correctional Facilities”?
It seems to me that the concrete and rebar should be the focus, but I'm running into resistance. I'd appreciate learning if anyone else has been up against this.
Baldwin2014User is Offline
20 Jan 2011 08:07 PM
Sorry, never been to jail.
radiantbarrierUser is Offline
21 Jan 2011 06:54 AM
I do know that BallistiCrete/PlasterMax has been used as an abuse resistant coverings for jails.
renangleUser is Offline
21 Jan 2011 12:04 PM
I believe that California is considering ICF for prisons...or so I have been told.
21 Jan 2011 12:13 PM
After much diiscussion, it turns out that the ICF is not really the concern. The sticking point is the finish. In order for ICFs to be considered for prisons, the finish material applied to ICF has to have been qualified under ASTM F2322-03 “Standard Test Method for Physical Assault on Vertical Fixed Barriers for Detention and Correctional Facilities” (http://www.astm.org/Standards/F2322.htm).
Anybody have any info on this?
21 Jan 2011 12:37 PM
Talk to Andrew Dennis of Gigacrete he could be helpful to you.
21 Jan 2011 01:02 PM
Am a distributor of GigaCrete and it has indeed been used in prisions, correctional facilities, goverment/military buildings.  It has been tested high abrasion and impact resistance according to ASTM C1629 and ASTM D5420.  Please contact me or see www.TheGreenBuildingProductsStore.com for more info
Callie Barrett
21 Jan 2011 01:09 PM
Thanks, folks. I have spoken with Andrew. He's done some testing, but I'm not sure if he's done this specific one. I am also not sure if this is actually the "right" test, as it is a fixed barrier test, and I would think that again goes to the steel and concrete. Does anyone know the argument for which is the "correct" test and why?
Testing was done over foam and it exceeded all requirments .
People Online People Online: Visitors Visitors: 236 Members Members: 0 Total Total: 236
