Question Mark
Last Post 21 Mar 2011 09:44 AM by thagreen. 3 Replies.
Jerry D. Coombs, PEUser is Offline
19 Mar 2011 01:02 PM
Sorry to post off-topic, but what is the big question mark in the yellow circle to the side of some of the posts?  I have looked and have no clue where to find this info.
JDC
<br>You can have with quality; You can have it fast; You can have it cheap.
Pick any two.
BruceUser is Offline
19 Mar 2011 01:40 PM
It is a, "Select a post icon to help classify your topic."  Next time you make a post, notice the option up near the top that you can select.
I now have a question for you.  In another post about CMU, you said you'd never make a 6" wall below grade full height wall even if the numbers worked out.  Was that about ICF as well as CMU?
Bruce
19 Mar 2011 08:26 PM
Thanks, Bruce.
Yes. for 6" wall, solid concrete, (usually 5.5" actual), backfilled full height, it's just going to make it easier to work with 8" If a short wall, not fully backfilled, it is probably OK, But for the difference it cost, I made mine 8". Have an engineer look at it for you and see what the numbers are.
Pick any two.
thagreenUser is Offline
Jerry,
The 6'' is the most common core we use and flies by no problem for strenght. However every situation is different.
Water pressure, bad soil, height of wall etc. will direct us to a thicker core. Also if it'll put the owner mind at peace
well i'd say that's a small price to pay for mental health.
People Online People Online: Visitors Visitors: 222 Members Members: 0 Total Total: 222
