Liteblok experience anyone?--dry stack insulated blocks
Last Post 01 May 2011 04:38 PM by npvisual. 1 Replies.
coyotejoeUser is Offline
10 Apr 2011 04:11 PM
I am considering the "grande" style blocks for a DIY 30x60' garage in Oakhurst, TX: http://www.crescoconcrete.com/ I see the following benefits: Only moderate skills necessary--no mortar expertise. Blocks are only 20 lb and easy to stack and align. Cresco video does not do it, but it seems I can bolt them solidly to the foundation as often as I like. R19 inherent in every block. Easy to finish/seal with a thick stucco paint. Blocks are locally made in Houston. Garage is on the highway, so great sound control Concerns: 1) Like Hebel, the blocks are actually metric. The layout must be in metric or it won't match up. 2) If it is such a great idea, why isn't everybody doing it? I got no hits for Liteblok in forum search engine. 3) Looks like a pain to get mortar down the little holes. Cresco also has a crew that will install the walls in 3 days. That seems pretty good. I bought a pickup load to play with and it seems workable. I was also thinking I might do the easy bottom section myself and let the crew do the top half (if they will agree). Any experience with these blocks would be appreciated. Joe
npvisualUser is Offline
Hi Joe,
Did you end up building your garage with LiteBloks ? If yes how did that go ?
Nicolas.
People Online People Online: Visitors Visitors: 234 Members Members: 0 Total Total: 234
