As Arkie mentioned another option for anchoring the trusses to the top of wall is to eliminate the wood plate and set the trusses on the concrete with wet set hurricane straps to wrap around the truss. You'll need to place roof felt between the wood and concrete and measure your truss placement real well. Or...
Use a Simpson Strong-Tie bracket with a metal plate the truss rests on and keeps it from contacting the concrete. Still need to measure well. Here's the website http://www.strongtie.com/products/c...AL-TSS.asp
Dave
