Alton
| 07 Aug 2011 11:33 AM |
Based upon past experience, what thickness of concrete would a 30' tall above-grade ICF wall with only one wood floor 12' from the footer be? This wall would support a roof and floor with a 24' span.
Later on the structural engineer will size this tall wall but in the meantime I need a feel for the wall thickness so that I can alter the floor plan. My guess is that the ICF wall thickness will about 8" of concrete plus 5.25" of foam for a total thickness of 13.25". For this type of tall wall above grade, would you describe the reinforcement as light, medium or heavy? |
arkie6
| 07 Aug 2011 06:41 PM |
Any seismic concerns? What about wind loading concerns? We have a 3 story Fairfield Inn here in Russellville, AR built with 6" regular LiteForm ICF (2" foam on each side) from footing to eves. |
Alton
| 07 Aug 2011 07:07 PM |
The site is near Jasper, AL. According to the code, the Basic Wind Speed for 50-year mean recurrence interval is between 90 and 100 miles per hour. The risk of earthquakes is probably low to moderate. |
Jerry D. Coombs, PE
| 12 Aug 2011 03:50 PM |
There are no "standards" or prescriptive methods for something like this. It needs an engineer's design by code, and just plain makes good sense. A lot of variables here. |
<br>You can have with quality; You can have it fast; You can have it cheap. Pick any two. |
