Other considerations...you live on a fault line, personally I think your better off in a concrete structure
I have thought about that. It is a definite consideration.
One more question: when trying to spec out a heat pump for the main floor, is there a rule of thumb to try to fit the right tonnage of system with the size and insulation value of the house. I have seen everything from a R22-R50 being quoted for the value of the walls and am trying to deal with HVAC people who are unfamiliar with ICF and how to fit the right system with what the house needs.
The basement will have radiant in the slab and a HRV unit for the whole house. Thanks
