Posted By narcszm on 10 Dec 2011 06:42 PM
Is it because of the asymmetry of the hooks that they tend to fail?
I think it is based primarily on theoretical failure based on calculations and assumptions rather than in-service failures of L or J type anchor bolts. In theory, under enough tensile strain, the L or J hook will straighten out and put out of the concrete.
I'm sure there have been documented in-service failures under extreme loads or due to poor installation (i.e. wet setting bent anchor bolts after the concrete has already begun to setup and not getting good bonding to the bolt), but I'm not aware of conditions where bent anchor bolts "tend to fail" if installed properly.
