Adding wood framed covered porch to icf house
Last Post 10 Jan 2012 01:15 PM by
FBBP
. 4 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
archimama
30 Dec 2011 11:52 AM
The house is already constructed and stucco is done. The homeowner wants to add a covered entry porch. What is the best way to attach beams and ledgers to the icf?
ICFHybrid
30 Dec 2011 02:16 PM
Cut down to the concrete face and use concrete anchors.
Chris Johnson
31 Dec 2011 11:25 AM
Simpson makes what I will call a reverse flange hanger, the flanges are to the inside of the hanger.
Carefully layout and remove the stucco and ICF to the concrete as tight as possible. If you are careful you will not have to re-stucco the wall
Insert and secure hangers with supplied screws, set beams and your done.
archimama
03 Jan 2012 04:35 PM
Thank you. This is what I figured I would have to do, but the builder is balking.
FBBP
Use standard wedge or epoxy type anchors into the concrete. Remove 2x2 of foam around the anchor and slide a piece of 2x2x.25 tubing (the depth of the icf) over the anchor. Seal tubing to stucco with sealant. Install ledger and tighten anchors to force the ledger into contact with the tubing. Alternate the anchors up and down to keep ledger in plane.
Membership:
croccohvacusa
People Online:
