Styrofoam teeth - first row
Last Post 22 Feb 2012 02:31 PM by dmaceld. 5 Replies.
jacktcaUser is Offline
21 Feb 2012 01:08 PM
I installed rails to hold the first row of ICF blocks into place.   What's up with the interlocking teeth on the bottom of the first row of ICF blocks?   Do you cut them off with a saw?    It seems like air/moisture could get into the house from the bottom if you don't cut them off.
21 Feb 2012 03:14 PM
No need to cut them off
Below grade you will be sealing the wall up to waterproof the area
If you have gaps of concern you can seal them with spray foam
21 Feb 2012 04:49 PM
Actually it's 4 feet above grade.  I'm in a flood zone and they made me build the house on a 4 foot high filled/compacted retaining wall.
Anyway, I got the answer that I needed.   After construction I'll just buy a can or two of great stuff and spray it in the cavities.   Thanx.
21 Feb 2012 05:09 PM
Great stuff is not so great!!
Ask your ICF supplier for his product
NFCUser is Offline
22 Feb 2012 12:37 PM
What type of blocks have teeth on the bottom? You're not upside down, are you?
Posted By NFC on 22 Feb 2012 12:37 PM
All of them, to match and interlock with the teeth on top.
People Online People Online: Visitors Visitors: 349 Members Members: 0 Total Total: 349
