logix radius walls
Last Post 09 Jul 2012 11:22 PM by Chris Johnson. 2 Replies.
rochUser is Offline
09 Jul 2012 07:39 PM
looking for feedback from anyone who has experience pouring a radius wall at a 12 foot elevation.I would like imformation on required bracing and pouring. thanks roch
TexasICFUser is Offline
09 Jul 2012 08:29 PM
Roch - be glad to discuss with you -- have done many. If you would like to talk pm me and I'll forward my cell number. Re the forum I use a different block and generally (but not always) purchase the block pre-cut for a given radius. Regards.
Install a complete course at a time, I use 1/4" plywood ripped into 4" strips to diaphragm it together, be prepared to make adjustments a few times on the first couple of courses, once these are perfect the rest goes easy and plumb. once done I diaphragm the inside as well with same strips of plywood, install braces and it remains stable for the pour.
That's my preferred method, I am sure there are others. I have seen people use just foam and tape, with the block being manipulated so much I get concerned over strength when concrete is placed.
People Online People Online: Visitors Visitors: 256 Members Members: 0 Total Total: 256
