Posted By JosephFearn on 11 Jul 2012 09:10 PM
In regards to the longevity of wood. Wood is being used to build/brace houses all across the world. Not sure what you mean by the question?
Yes, but the wood to build homes is protected from the elements (sun & moisture) by exterior sheating. My question was in regards to using wood bracing that will sit out in the elements as the wall is setting. The wood bracing will sit on job sites where the sun will bake it and it will get rained on. What is happening to the untreated wood bracing that sits out in the elements and is later used for bracing?
I'm not knocking the product, I just know that job sites and job site products are not treated well by either the workers or the elements. A piece of steel is much stronger and one does not have to worry about it warping because it got wet.
