Posted By R9tobon on 17 Jul 2012 11:18 AM
My issue with portable vacuums that recycle vacuumed allergens back into the air! the central vacuum system draws these allergens out of the house and into the garage, where they are then exhausted outdoors where does a portable vac exhaust? Portable vacuum cleaners cannot promise the same results because they do not transport the allergens outside of the living environment where a central does.
Think about it.
used to be true, but most have good HEPA filters. down to .3 micron.
The ones that don't can often be upgraded. I did on mine.
After another broke, I took it apart in a vain attempt to fix. These things
are designed, constructed and sealed well enough to not worry about them
recirculating dust. Even my shop vac comes with 1 micron filter.
.3 is tobacco smoke
1-5 is fine drywall/chalk dust
Biggest help for us on IAQ was switching from asbestos wrapped 50yo dusty
HVAC to radiant. Still need to put in a HRV.
allan
