Posted By MerlinMc on 26 Aug 2012 08:49 PM The Seattle Children's PlayGarden "Garden House" (building with the green roof in the photo) was built out of ICFs. Both the exterior and interior walls and windows sills are coated with smooth concrete so that the walls look like solid cast-in-place concrete. Any ideas on what coating they might have used? Thanks.
Posted By ICFcoatings on 27 Aug 2012 10:29 AM StuccoMax and PlasterMax have been designed for the ICF industry and provide the most abuse resistant available and apply quicker than traditional materials. These products have been used in schools.military, hospitals, correctional facilities and more. Happy to provide more info.
Posted By ICFcoatings on 28 Aug 2012 10:40 AM Weep screeds are used as a precaution but StuccoMax does not have water issues. It's performance is unmatched with excellent water resistance. There is no efflorescence with StuccoMax as there is with traditional stucco made with sand and mortar. Traditional stucco is a porous material which permits moisture to move both in and out of the wall. StuccoMax does not crack or shrink like others and is much quicker to install also. Let us know if we can provide more info.
Posted By ICFcoatings on 29 Aug 2012 08:48 AM StuccoMax is water resistant but water can always get "under" around windows/doors if those areas are not properly installed. 11 oz fiberglass mesh is normally used. Do not personally know of AZ installs but would think there are.
