A Woodpecker is damaging my icf walls.
Last Post 17 Nov 2012 03:19 PM by cbryndal. 13 Replies.
theInvincibleUser is Offline
21 Oct 2012 10:14 PM
Why is a woodpecker damaging my ICF walls and how do I stop it? I am planning to kill it. Do you have any better solutions?
ICFHybridUser is Offline
21 Oct 2012 10:21 PM
I'd also be worried about whether it is actually getting any bugs in there.
Is your place just not finished yet, or is the ICF actually exposed? My cat ripped some of my walls to shreds during building, but the damage was easy to patch. Wood pecker holes could be filled with sprayfoam.
Best to permanently remove animals that are (dead)set on a particular mindless behavior.
22 Oct 2012 12:38 AM
Posted By theInvincible on 21 Oct 2012 10:14 PM
Need to clarify what is going on here. Is the ICF exposed? Is their concrete inside the ICF? Why isn't there a finished exterior surface (stucco, siding) on the ICF?
jdebreeUser is Offline
22 Oct 2012 07:15 AM
Woodpeckers will bang on things to make noise- they've been observed hammering on metal light poles. I don't think they could get much noise out of ICF, though. I think it's illegal to kill one, so better keep it to yourself. On a related note- I had carpenter bee damage on my ICF. Not enough to cause concern, though.
Gary OlsenUser is Offline
22 Oct 2012 08:30 AM
Since woodpeckers are migratory, federal law and international treaties protect them. However, if they are damaging your house, you have a right to protect it. That could mean many things as a defense.
Woodpeckers thump on anything that makes a good noise (to them). It marks their territory and can also be part of the mating ritual. This is their behaviour here in CO in March, not now. Consider your abode a large bongo drum.
This is annual behaviour. Which means, it could continue, unless you cover the ICF with something that deadens the bongo like noise. I have seen them take 5 gallons of EPS out of the hole in thin stucco siding to make their nest. One house I repaired had 300 woodpecker holes in the thin stucco.
good luck
ICFcoatingsUser is Offline
22 Oct 2012 09:24 AM
Use STUCCOMAX, we have never seen a woodpecker be able to penetrate our product. Our products are abuse resistant and even ballistic resistant.
BrianBaronUser is Offline
22 Oct 2012 11:52 AM
^ That way if you miss with the pellet gun, the house will not be damaged... Sounds like two benefits to me!
22 Oct 2012 12:09 PM
thanks Brian it is a remarkable product
please see more info on www.stuccomax.com or on our facebook page at http://www.facebook.com/pages/Barrett-Enterprises-Inc/174646172589879?ref=hl
22 Oct 2012 09:34 PM
Posted By ICFcoatings on 22 Oct 2012 12:09 PM
Anyone in Arizona install it?
22 Oct 2012 09:36 PM
Posted By jdebree on 22 Oct 2012 07:15 AM
I've seen them penetrate soffits and create so many holes in wood soffits that they had to pull the boards down and replace them.
I can't see a woodpecker penetrating 6" of reinforced concrete or penetrating 24 gauge steel.
22 Oct 2012 10:20 PM
Concrete is not poured yet. I checked the hole today. It was like a nest. I put some sprayfoam in it.
12 Nov 2012 03:47 AM
What kind of expansion rates does StuccoMax experience? Does it have any R-Value to it?
So with detail work, basically at the bottom of the stucco wall it just closes itself off, no weep screed? What about around window frame areas?
insuldeckfloridaUser is Offline
17 Nov 2012 10:46 AM
thin, soft stucco/eifs coatings are no defense against woodpeckers
impact rated eifs works, as does real "old world stucco"
or hardie type cementicious siding
cbryndalUser is Offline
Let them eat. We have some exposed spray foam left over that isn't yet covered and I've chucked 3 bird-bodies into the forest. They don't seem to last long with the plumbing filled with foam. And there's no feedback mechanism to inform future attempts. To get around the international treaties - you could simply detain them indefinitely. (food source notwithstanding)
People Online People Online: Visitors Visitors: 288 Members Members: 0 Total Total: 288
