Radius walls
Last Post 06 Jan 2013 10:55 AM by ICFconstruction. 5 Replies.
eiland29User is Offline
04 Jan 2013 06:13 PM
What do people use to make accurate notches for radius walls? Just making 2 cuts per notch are using a tool set to proper width
04 Jan 2013 06:34 PM
We are doing a 10' radius, 14' tall, a circular saw with the guard removed and blades stacked to 9/16". hand cut reliefs in the outside. Hardboard siding strips to tie it together.
04 Jan 2013 08:37 PM
On a similar but different note
When you have a set of windows above another set of windows, is 15" enough spacing between the windows to get the bucks in, forms, rebar, ICF, concrete?
What about window to corner or a set of windows to another set of windows? Is 12" from a window to a corner or window to window enough spacing or does it need to be widened?
05 Jan 2013 10:10 AM
Window above a window, so a lintel? 15" enough? Depends, how wide are the windows? How much is your buck taking up? What is the load above? Will they be part of the same pour? If so, you can put in rebar as if it is one opening?
12" in-between side by side windows or a corner, I don't usually have a problem with, a lot of variables there too. but I think the code may require 24".
06 Jan 2013 09:21 AM
Posted By ICFconstruction on 04 Jan 2013 06:34 PM
No guard? The saw mans nickname is stubby?
Just the retracting guard is removed, but Lefty is safe when he uses it.....now.
People Online People Online: Visitors Visitors: 273 Members Members: 0 Total Total: 273
