ICF pour duration
Last Post 31 Jan 2013 04:56 PM by
cpd159
. 4 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
cpd159
31 Jan 2013 02:19 AM
Hello all in the process of a diy ICF house. 30x80 ranch. I will most likely being using fox block because of local suppler. It will be a full basement and ICF main level. Ive searched and cant seemed to find a pour duration between the basement pour and the main level pour. I'm trying to estimate a construction schedule. So after pouring the basement is there a recommended waiting period before the next level pour? Thanks for your time
smartwall
31 Jan 2013 09:44 AM
The pour duration will depend on a number of factors. This time of year it's all about the temp. Cold and wet means the CC stays green for a longer time. I use a water reducer year round, this reduces the time the CC stays green. There are no set rules. One easy test is to take a flat screw driver go about half way up the wall, stick it in and give it a twist, if it goes in easily leave the walls alone . With an icf it dries two ways, thru the top and footing
ICFBdr
31 Jan 2013 10:40 AM
Concrete reaches approx 40% of compressive strength after 4 days and approx 70% after a week. I would wait a few days before installing the floor system. Assuming this takes a couple days (or more) and then another day to waterproof and backfill, you will be at a week before starting to place the main floor blocks. I recommend installing floor system prior to backfill (especially if a 6" form is used below grade) if you have a higher grade height. This gives the basement walls lateral support at the top and provides extra strength against the force of the ground.
theInvincible
31 Jan 2013 12:26 PM
If you are aggressive use concrete that is cured in 24 hours, than you can the pour the slab next day.
Are you planning to make a record.
cpd159
Thanks guys. I'm planning on using a 8" block for the walkout basement and 6" block for the main level. I will definitely put the conventional floor on and then waterproof and backfill which will take approximately 3-4 days. I just didn't want to go up with the main floor to soon.
Membership:
croccohvacusa
People Online:
