Posted By tuffluckdriller on 25 Oct 2013 01:46 PM
So I have a lot I'd like to build on, but it has expansive soil. A solution to it is to install micro-piers. These would be 20'-40' deep x ~4" holes drilled every ~8' under the foundation walls. They are then sleeved, rebar installed, and concrete poured into them.
I'm just wondering if anybody here has experience with this type of construction when using ICFs. We'll have a full basement. Is there differences in the construction of the ICF wall in this case?
Thanks all!
We have use minis in commercial construction but in our case we used 5" heavy wall pipe down to bedrock (between 17 and 30 feet) and filled them with grout. The pipe is the strength and the grout prevents bending. I don't think this will work unless you have bottom bearing.
If you use piles, what will you do to prevent the floor from moving?
