TF Systems New VerticalFoam System
Last Post 05 May 2014 11:26 AM by smartwall. 1 Replies.
sailawayrbUser is Offline
05 May 2014 10:40 AM
We just learned that TF Systems now has a new ICF system that allows the use of any foam board that you can source locally. Their new system is called VerticalFoam and more info is available on their website. This new system allows you to purchase 4 x 8 sheets locally and then either cut the required 8” wide vertical slabs on a table saw or purchase one of their hot wire cutters that cut whole 4 x 8 sheets into the required 8” wide vertical slabs. Then you use their existing corners, studs and c-channel to build the system. That way you only have to ship these components and not the foam.
Our biggest issue with TF Systems has been the high shipping cost associated with getting their foam to the west coast. We are not affiliated with TF Systems in any way, but we are always looking for innovative ways to do things better and at lower cost for our customers. If anyone uses this new system, please post your experience.
smartwallUser is Offline
Had a chance to use their TF system last year on a project. Came upon a warehouse that had a bunch of the product in storage since ' 08 ,cancelled build. I gave it a try and surprise it is half the labor that Hobbs says on it's web site. I just priced out 2 projects and will be using TF on both. As you said I'm sourcing 3" 45 lb xps from a roof project for my foam at an very attractive price.
People Online People Online: Visitors Visitors: 161 Members Members: 0 Total Total: 161
