Posted By FBBP on 18 May 2014 08:40 PM
Actually, its as Chris Johnson said. The engineer can cut as many integral joists as he needs to as long as he makes up for it somehow. It's no different then making a big window opening in a wall. Just put the right sized header over it.
Quite true. Window openings are a simpler design issue because there the structure lines up with the load where with joists the load is perpendicular to the structure. I was thinking in terms of plumbers and HVAC guys who willy-nilly cut joists when they get in the way. When I designed and built my house I was able to line up all the mechanical to fit between the joists. Did have to do some finagling of fixture and equipment placement, but nothing significant. The only joist I had to cut out was for the crawl space access, and that was in a short joist with light loading so transferring the load from the cut joist to the others was no concern.
I'm only vaguely familiar with Insuldeck but I would think that fitting in headers and adding reinforcements to make up for the cut joists would be complicated enough to make one think twice about doing it.
Obviously, if the access hole is close to the supported end of the joist it'll be a lot easier to adjust for it than if it's near the center of the joist.
