ICF Conditioned Crawlspace. Vapor barrier
Last Post 29 Jul 2014 05:13 PM by ICFcoatings. 3 Replies.
GADUser is Offline
28 Jul 2014 11:00 PM
I am replacing my vapor barrier that was poorly done. It did not even go up the walls, all the tape is coming up. Its a redo. I have a conditioned crawl space with the exterior walls made of ICF. What do I use to seal the 12 mil POLY to the ICF crawl space wall? Will butyl tape work? Thank you for your help!
GAD
scicfUser is Offline
29 Jul 2014 07:41 AM
I use a/c mastic on the wall. Apply mastic, pull barrier up just past mastic and secure barrier with a 1x3 placed over the mastic and screwed to the wall. This forms an air tight seal. It's messy but it seals completely.
GADUser is Offline
29 Jul 2014 04:45 PM
Never thought of that. Thanks for your help
ICFcoatingsUser is Offline
Best product to use is THE BARRIER   read about it and you will see why, is a vapor barrier/ radon barrier, bug resistant, insulator and much more. www.barrett-inc.com/barrier.php
People Online People Online: Visitors Visitors: 221 Members Members: 0 Total Total: 221
