HVAC Load Calcs ICF Home - Did I do this right?
Last Post 15 Feb 2015 11:29 PM by dmaceld. 11 Replies.
craigtooUser is Offline
07 Nov 2014 04:18 PM
I would appreciate opinions on the validity of this load calculation.  I'm very new at this, and am not really sure I did it correctly.  I would like to use Mitsubishi Mini-Splits for Heating and Cooling - I think.  I'm open to any suggestions.  I plan on working with an HVAC pro, but I want to be sure at least I know enough to be dangerous (or annoying) before I contract any one...
Thanks all!
Particulars:
Home in Annapolis, MD
Waterfront (but well protected).
Front of house faces NW.
ICF Construction -
Walkout basement of which approximately 50% of total wall space is underground.
36 x 40 Foot Print
Unfinished Basement, Main Floor (Great Room, Master suite, kitchen Living area) and Lofted Second (2 Bedrooms, bath and laundry)
Cathedral Ceiling - R49
LowE Glass
LowE Smart Sun on NW facing  (Andersen  400 Spec)
So, here are the results of HVAC load calculations using "Mass HVAC Sizer V4.0"
EDIT:  I apologize.  Links not working.  Standby.
07 Nov 2014 04:22 PM
[URL=http://s660.photobucket.com/user/craigtoo/media/Load_Calc_3.jpg.html][/URL]
07 Nov 2014 04:24 PM
[URL=http://s660.photobucket.com/user/craigtoo/media/Load_Calc_4.jpg.html][/URL]
[URL=http://s660.photobucket.com/user/craigtoo/media/Load_Calc_1.jpg.html][/URL]
[URL=http://s660.photobucket.com/user/craigtoo/media/Load_Calc_2.jpg.html][/URL]
07 Nov 2014 04:25 PM
[URL=http://s660.photobucket.com/user/craigtoo/media/Harbauer--1.jpg.html][/URL]
07 Nov 2014 04:26 PM
[URL=http://s660.photobucket.com/user/craigtoo/media/Harbauer--6.jpg.html][/URL]
Eric AndersonUser is Offline
07 Nov 2014 09:08 PM
I have not used that particular program, but considering the design temp for Baltimore is 15°F I ballparked the heat loss at ~7200 windows, 7300 walls, about 4000 ceiling, I took a wag and said 2000 for subsurface walls, and another 3K for slab losses, since it is a walkout and I don't know what is under the slab for 23K Add infiltration, which is A total crapshoot if it isn't measured and I would have half assed ball parked it at 30K.
In part I would have bumped up my guess because with that much glass, the mean radiant temp is going to be low and you will likely bump up the thermostat a bit higher to be comfortable.
In other words, you are in the ballpark, and the inputs don't seem strange.
Cheers,
Eric
07 Nov 2014 09:59 PM
Thanks for the smell check!
Titan ICFUser is Offline
04 Dec 2014 11:33 PM
Nice drawings, looks like cheif... My rep uses remrate I think. He's tried a few of them, some are buggy and some are not. I like this one you are showing. Some of the man j reports are too much for most people.
"If you think it's expensive to hire a professional to do the job, wait until you hire an amateur." Red Adair
JimUser is Offline
15 Feb 2015 03:41 PM
where did you get that program?
Posted By Jim on 15 Feb 2015 03:41 PM
This is the one.
http://members.cement.org/EBiz55/ProductCatalog/Product.aspx?ID=14
Contact the PCA to see if they plan to have an updated version available. Send me a PM about what you learn and we can go from there.
People Online People Online: Visitors Visitors: 140 Members Members: 0 Total Total: 140
