geothermal under basement.
Last Post 25 Mar 2015 07:01 AM by
joe.ami
. 4 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
tjorissen
21 Mar 2015 04:52 PM
Was wondering about putting geothermal hoses about 2 feet under my basement floor. We plan on building a 1800sqft house with a full basement. Were located in west michigan. Was looking to save money this way. Is this a good or bad idea?
joe.ami
22 Mar 2015 09:18 AM
You might get more interest in the "geothermal" section.
There are applications of geo loops under the foundation, but usually they are vertical.
Without knowing your heat loss/gain, I don't know that you could fit enough horizontal loop under your home.
On top of that because heat goes to cold, you could actually drawheat from your basement (I know one kook who suggests this is an advantage). To mitigate that you would want to install 2" foam under the slab at loosely $1/SF. Coincidentally excavating 2 or three trenches is less than $1,000.
1 story or two? Where at in West MI. We have clients all over MI.
You are likely to be in the neighbor hood of a 3 ton if you are using code minimum insulation, but could likely get that down to a 2 ton if real care is taken to build a tight home.
tjorissen
22 Mar 2015 11:44 AM
Sorry, I'm new to this site.
It's a one story near Ludington MI. Also using an ICF basement.
billnaegeli
22 Mar 2015 05:11 PM
yep i agree with the veteran, i would go to the geo section
GNP Inc
ICF Construction & Concrete Services
1-800-713-7663
joe.ami
Since you have indeed asked the same question on multiple forums and sub categories I suggest we let this thread pass and converse elsewhere.
Membership:
croccohvacusa
People Online:
