Cost to build an ICF structure in Northern NJ
Last Post 05 Apr 2015 01:24 AM by Lbear. 4 Replies.
BBMWUser is Offline
26 Mar 2015 12:39 PM
I'm a real estate investor. I'm currently active in Northern NJ, in the Jersey City, Weehawken, West NY, corridor. I see a number of vacant buildable lots and/or teardown buildings available. If I can get one or more of these, I'd like to build these as 3-4 floor, 3-4 unit buildings. It would probably be advantageous to build them in masonry. So I'm considering ICF as an option. What I need is some sort of cost estimating methodology. Is there a thumbnail cost per sqft number, for either/both basic framing and completed construction? Is there any other method? Assume bare land. Thanks
BrucePolycreteUser is Offline
26 Mar 2015 02:52 PM
BBMW - I just sent you a PM. We are active in your area doing mid-rise residential.
billnaegeliUser is Offline
26 Mar 2015 08:18 PM
we would like to talk with you, we are ICF contractors and can give you good numbers turnkey and sub quotes as well as design/build capabilities. contact me directly for cost info thanks GNP Inc
GNP Inc
ICF Construction & Concrete Services
1-800-713-7663
TravelUser is Offline
04 Apr 2015 08:21 PM
We have been installing residential and commercial ICF for over 11 years we make a point to be the best at what we do. Quality. Percise and affordable
Posted By BBMW on 26 Mar 2015 12:39 PM
The cost of ICF is calculated as wall square footage and that includes the window and door areas. It's basically an OTD (out the door) price in that it contains the cost of the ICF/forms, rebar, concrete, bracing, labor, window/door bucks, etc. It's also regional dependent and based on complexity but "thumbnail" cost is around $10 - $15 per square foot.
