If you aren't interested in insulating the wall or finishing the interior, you will be able to easily find a subcontractor to charge you less for the metal forms. If you're planning to fur or stud out the interior and need insulation, your cost for the traditionally formed wall should be less, but your total cost may be more. When compared head to head with similarly performing wall systems, the ICF wall is normally cheaper than traditionally formed concrete or reinforced masonry. |
