Hello,
Thanks much for the response. I'm not sure if I'm understanding what you are saying for sure, so I drew up a diagram based on what I think you might be saying -- can you tell me if that is what you are talking about or if I did it incorrectly? And yes, I realize I wouldn't want the footings to be exposed like that and they wouldn't be -- in my original diagram I had left off the stem wall which goes down 4' and I'm putting 1.5" XPS on the outside of it.
So on this new diagram I have, after ICF pour is done, putting 2" XPS insulation down through the door rough opening and then building a 4" riser of 1.5" XPS on the outside edge of where the door would go, and then pouring the 4" slab all the way to that. Is that kind of what you were talking about doing? Thanks for the help.
