Stripping Foam necessary for Radon sealing?
Last Post 23 May 2016 11:09 AM by FBBP. 21 Replies.
NashvegasUser is Offline
07 Apr 2016 10:53 AM
I think the original design was way off. But I will have to wait for the new engineer to see what he comes up with. I'll let y'all know when I get that back in a couple weeks. Cross my fingers. At $165 a yard, I'd like to save what I can.
FBBPUser is Offline
Posted By Nashvegas on 02 Apr 2016 11:20 AM
Lots of good comments. Thanks everyone. For snapping a chalk line, that could be done before I lap up the plastic. 6 mil should allow the line to be visible, especially in done in black chalk. The engineer at this time has simply designed the radon line as a perforated line down the center. The drain is on the exterior. We only get 10" of moisture a year here, so sumps are not used. A good point is raised about why radon collection is not done on deep walls, but that should be solved by the waterproofing, especially if peel and stick. That's a lot thicker than 6 mil. I'll discuss with the concrete guy about Form a Drain. The footers are engineered as well right now are 6 foot wide, 3 foot deep with tapered sides and a bunch of steel. The original engineer died ( yeah the project has been in the works for a while) and I'll have a new one reviewing the design
Consider lapping the poly down to the footing rather then up to the ICF.
People Online People Online: Visitors Visitors: 319 Members Members: 0 Total Total: 319
