ICF vs EPS block
Last Post 15 Jul 2016 05:36 PM by InsulaBuildingSys. 1 Replies.
minotto disegnoUser is Offline
15 Jul 2016 12:35 PM
I saw a video of a small home constructed in 7 days using EPS block. Filled with rebar and concrete, it seems the benefits are the same as ICF. Though maybe round walls are possible with EPS block and not ICF? Has anyone worked with EPS block in residential home construction? Are there any differences between the 2?
InsulaBuildingSysUser is Offline
ICF panels are made with expanded polystyrene, or EPS. ICF blocks, when assembled, are also filled with rebar and concrete. Perhaps the two systems you are referring to are one in the same thing but with a different naming convention. A link or reference to the video would be helpful in answering your question, but I will add that you can definitely build round walls with ICF.
People Online People Online: Visitors Visitors: 423 Members Members: 0 Total Total: 423
