ICF panels are made with expanded polystyrene, or EPS. ICF blocks, when assembled, are also filled with rebar and concrete. Perhaps the two systems you are referring to are one in the same thing but with a different naming convention. A link or reference to the video would be helpful in answering your question, but I will add that you can definitely build round walls with ICF. |
