What should I look for in structural engineer for a ICF home?
Last Post 20 Apr 2017 11:49 PM by Geergirl. 7 Replies.
samautoUser is Offline
21 Mar 2017 09:01 AM
What should I look for in structural engineer for a ICF home? Can any structural engineer do the engineer for an ICF home etc?
arkie6User is Offline
21 Mar 2017 10:20 AM
Do you need a structural engineer? If your home design is relatively simple and in accordance with the prescriptive method, a structural engineer may not be required.
http://buildblock.com/asked-answere...thod-talk/
PRESCRIPTIVE METHOD FOR INSULATING CONCRETE FORMS IN RESIDENTIAL CONSTRUCTION Second Edition:  http://www.huduser.gov/portal/Publi...cf_2ed.pdf
If you do need or desire to use a structural engineer, I would consult with your proposed ICF builder and get their recommendations.
sailawayrbUser is Offline
21 Mar 2017 02:37 PM
Yes, precisely what Arkie suggested plus if you elect to hire one, make sure s/he actually has a professional engineering license in structural engineering in the state you are building. Obtaining a professional engineering license in structural engineering requires additional experience and testing beyond what is required for a professional engineering license in mechanical or civil engineering.
ronmarUser is Offline
21 Mar 2017 05:32 PM
Also the Concrete Contractors who build ICF in your area may be able to recommend someone familiar with ICF.
Along the lines of the prescriptive method, PCA-100, available free from the Portland Cement Association, is an excellent resource, especially if you are in a seismic zone(D1-D2) as their prescriptive tables are approved for use there(as are ACI-318 if I recall correctly).
Depending on your plan, A PE analysis may actually pay for itself in rebar cost savings over a prescriptive design, mine did... The plans also zipped right thru the building department review with the engineers stamp on them
toddmUser is Offline
22 Mar 2017 05:47 PM
You may need an engineer's stamp to get a building permit. In Pa, for example, if it's not in the IRC's prescriptive code, it must be blessed by an engineer. Start with your building department. If you need an engineer, ask the inspector for names. (If he's prohibited from making recommendations, ask him what engineer would turn up most often if a diligent permit seeker scoured the public records.) Local form suppliers will recommend engineers. I'd steer clear of asking contractors for recommendations for fear of hearing names chosen for pliability rather than expertise. The guy I found was a true believer, owner of a massive ICF house he built himself and worth the money.
GeergirlUser is Offline
20 Apr 2017 12:45 AM
We went with a local engineer who is one of the few that stamp residential in our small city. Teaches at the local college too.
We've found if you say CONCRETE and the structural engineers' eyes light up, your probably good to go.
20 Apr 2017 02:59 AM
Posted By Geergirl on 20 Apr 2017 12:45 AM
That happens with most structural engineers... For some reason they love that stuff:)
@ronmar - yup, and that makes them great for ICF projects!
People Online People Online: Visitors Visitors: 326 Members Members: 0 Total Total: 326
