I did speak with someone at Nexcem who explained that the dead links on their website are because they are moving over from the Durisol website... it is somewhat fishy. Why change to such an odd name? Nevertheless, the contact at Nexcem was happy to email me the Technical Guide, which I now have. The document says the following
Nexcem Wall Forms are designed to ensure that the R-value through the core of the wall is almost the same as that through the web. This not only avoids thermal short-circuiting, it ensures uniform wall temperatures with no cold spots to encourage condensation, create discomfort, or cause dust marking.
The Tech Guide also states that "Specific test reports on topics such as thermal resistance" are available upon request. I will request these and see what I can find.
To be clear, I am personally not considering this as a replacement for a full wall system, just as a replacement for stem walls and foundation walls, so I am comparing them to solid concrete in terms of performance/cost. I have not even figured out what the cost differential between a durisol wall and a poured concrete wall is, but I have a price list so I will be doing that shortly.
The Tech Guides asserts that the "standard Non-thermal Wall Form unit has an insulation value of R8." In other words, the block itself is giving R-8, and the added rockwool is increasing this somewhat... They are also very clear that the poured concrete in the middle of the blocks is what should be counted on in terms of structural capacity.
