Icf internal structural support
Last Post 12 Feb 2018 06:08 AM by Dilettante. 1 Replies.
Construction Haute SavoieUser is Offline
11 Feb 2018 02:36 PM
Hi all, I am hoping to build an icf home. I am designing the home myself as much as possible. Before I employ a structural engineer I would be very grateful if someone could advise here. So our ground floor, which will be semi sub grade built into a slope, will measure approximately 18m long and 6m wide. This will have an icf flat roof/floor as more than half of it is exposed as garden space. The top two floors will be sitting perpendicular on it, like a cross essentially. Does the ground floor require supporting walls or lintels for the above walls or can the 5m span support it? Then above we have a structure measuring 14m long by 7m wide, nearly two stories high with a mezzanine over half the 1st floor. Again, can the icf span 7m across with no structural vertical support below? And lastly, with an icf roof on the 7m wide structure, with an overhang of a metre or so, and a 35* pitch, can this be supported by a cast in ridge beam 14m long, with no vertical support needed underneath? Lastly, the mezzanine will cover 9m of the 14m, leaving a void over the living room. If support is indeed required for the roof, we could have a beam in the mezzanine floor 4m in and spanning the 7m width, and then a column to the roof, but hope this is not necessary. Any advice would be hugely appreciated. I hope I've made it clear. I've attached pictures to help. Cheers
DilettanteUser is Offline
Unfortunately, your pics didn't make the transition.
The board software here is kinda old and broke.
Just post hyperlinks to the pictures
http://www.yourwebsite.com/yourpicture.jpg or the like.
People Online People Online: Visitors Visitors: 479 Members Members: 0 Total Total: 479
