Tongue and groove
Last Post 26 Sep 2018 08:39 AM by scottishjohn. 13 Replies.
JasonwickUser is Offline
22 Apr 2018 12:14 PM
What fasteners should I use installing t&g over drywall in basement,foxblocks,also contractor did not install any outlets ......24 × 60 home
23 Aug 2018 11:14 AM
Horizontal I hope. Try a few trim nails, but with the drywall they will have to be long. See how well it holds and how tight the boards are to the drywall. You could add some adhesive too. Usually we screw everything to ICFs but with paneling it would be a hassle. I nailed T&G to BuildBlock, no drywall. I hit every web, 6" oc and it holds very well.
23 Aug 2018 03:24 PM
Posted By ICFconstruction on 23 Aug 2018 11:14 AM
Ring shank trim nails would likely have marginally better retention than bright trim nails, but adhesive is still might be necessary.
Using half inch OSB or CDX instead of gypsum board under the t & g would provide a far superior nailing substrate.
newbostonconstUser is Offline
23 Aug 2018 05:30 PM
I total thickness needs to be 3/4. That is alot of money....drywall alone is the cheap answer.
23 Aug 2018 11:54 PM
But how much holding power do you need?
ICFBdrUser is Offline
24 Aug 2018 02:21 PM
If the outlets are not installed, why not remove drywall, install outlets, then install T&G directly to ICF???
24 Aug 2018 03:12 PM
T&G alone isn't thick enough to meet fire code I believe.
Drywall might be glued also.
24 Aug 2018 03:32 PM
Posted By ICFBdr on 24 Aug 2018 02:21 PM
Sounds good.
24 Aug 2018 03:55 PM
Posted By newbostonconst on 24 Aug 2018 03:12 PM
For easy attachment, replace drywall with 1/2" plywood then nail to that....more cost/work, but easy attachment of T&G
24 Aug 2018 04:29 PM
The heck with code, the owner should decide for themselves. I would (did) attach direct to the ICFs with nails only.
24 Aug 2018 06:59 PM
Posted By ICFconstruction on 24 Aug 2018 04:29 PM
If there were ever a fire I'm sure the insurance company will use that to their benefit, not yours.
The combined thickness of 1/2" OSB + t & g paneling would probably be sufficient to meet spec as a timed thermal barrier, but unless somebody has tested that stackup it may not fly with an inspector (or insurer.)
Not that it matters- the OP hasn't posted for months, and has probably already made a decision and went with it.
24 Aug 2018 07:46 PM
Right if it isn't tested it isn't a government approved nothin'. We all should be making our own choices. As far as insurance it does not matter. An insurer cannot deny a claim for negligent work by an insured, in fact that is a big part of what insurance is for. Not that this is negligent. Insurance policies are voided by deliberate acts to cause a loss, and the burden of proof is high. Stupidity is covered.
DilettanteUser is Offline
27 Aug 2018 04:04 PM
If you're worried about fire rating, you could always invest in a bucket of PinkWood's PKshield/PinkShield product.
Take your plywood, coat it, let it dry.
Won't make it fireproof, but it'll drastically increase ignition times.
scottishjohnUser is Offline
most ICF systems in UK have "furring" strips built into the ICF form -every 8 or12"-metal strips you can self tap into -if you can find these then you can screw your battens to them to make services gap and fix T+g--yes drywall will be stuck on --so check tech spec for your ICF system --find one and the rest will be easy. you could use screw type dry wall fixings like for hanging big pictures --all depends on how well you think the dry wall is fixed to start with then the final way is to dry and fix battens direct to the actual concrete with long screws . Me I would go for long s/s screws into the concrete all simple DIY stuff.
People Online People Online: Visitors Visitors: 295 Members Members: 0 Total Total: 295
