ICF and Water Proof Slab
Last Post 17 Nov 2018 06:02 PM by Dean Prince. 6 Replies.
Dean PrinceUser is Offline
12 Nov 2018 08:20 PM
I live in northern British columbia, Canada, and my home will be built on consolidated Clay. I have a drier location and I am using ICF and Monopore system for my foundation. I am building a Slab on grade, so no basement.....the question is....should i still waterproof the ICF even though I have no living space under my slab?
ICFBdrUser is Offline
13 Nov 2018 03:06 PM
WP is not required unless the backfill is higher than the level of interior finish. In other words, if the ICF is buried inside & outside (ie, frost wall, grade beam, etc) no WP is required (unless local code is unique in your area - may be best bet to check with your local code official).
DilettanteUser is Offline
16 Nov 2018 10:22 AM
"Waterproof" in the traditional sense? Probably no.
You will STILL want to have a vapor barrier (fluid-applied, peel & stick or wrap) however.
And, depending on your exterior finish, you'll want some sort of air gap between the cladding or an integral drying layer underneath something like stucco to allow water to properly escape the wall assembly.
16 Nov 2018 09:20 PM
Again check local code, but 9.13.2.1(1) in 2015 National Building Code of Canada states that dampproofing is only required where in-fill is lower than backfill. Unless your local code has other requirements, an ICF frost wall that is buried on both sides should not need to be dampproofed/waterproofed.
scottishjohnUser is Offline
17 Nov 2018 10:02 AM
I asked same question of a couple of concrete suppliers
all said yes but it will double the price of the concrete,which is why everyone goes for underslab dpc tanking of walls if below grade walls encompass usable area
17 Nov 2018 06:00 PM
ahhh. vapor barrier under the slab, but the ICF is already concidered a vapor barrier, correct?
yes, inspector says no waterproofing required. thank you
People Online People Online: Visitors Visitors: 255 Members Members: 0 Total Total: 255
