Window in relation to ICF wall corner
Last Post 21 Dec 2018 10:38 PM by minotto Disegno. 7 Replies.
minotto disegnoUser is Offline
07 Dec 2018 01:11 AM
Hi, Given a typical ICF corner wall (6" core), how close can a window be installed to the corner? Is 4" too close?
07 Dec 2018 01:13 AM
Posted By minotto disegno on 07 Dec 2018 01:11 AM
TexasICFUser is Offline
07 Dec 2018 03:32 AM
According to the prescriptive method yes. However, with a little engineering assistance you can easily accomplish- even to the point of having all glass window corners. Regards
07 Dec 2018 05:30 AM
Keep in mind how you are going to trim the windows. You don't want to crowd the final trim pieces to the point of looking cramped.
It's kind of like when I designed my house. I couldn't design the hallways until I knew how and what I going to trim the doorways. Door width + trim width + space for pleasing look! In other words, the hallway depended on the door casing!
ICFBdrUser is Offline
07 Dec 2018 02:21 PM
Where are you building? Canada's Building Code doesn't allow openings in ICF walls to occur withing 1200mm (4 feet) of a corner. It is a terribly restrictive part of NBC. Similar restrictions are not placed on design if building under the umbrella of an ICF manufacturers design (or get an engineer to review/approve your plans).
07 Dec 2018 03:49 PM
Thanks for all the answers.
The home will be in S. California. It will be contemporary in style so no trim, casing around the window opening. The window in question is floor to ceiling is 12' x 4'. I was just wondering how much room i would need from the corner.
rvalueUser is Offline
21 Dec 2018 10:33 PM
I recommend you download and read the prescriptive method. Also many of the block manufacturers have their own engineering documents that may shed some light on things. If your desires fall outside what is allowed by either of these documents, you can alter the design or hire an engineer. It might take a while to read and understand these, but they are written in laymen's terms. You won't regret it.
Details matter!
Jake Vierzen
R-Value Homes
Grand Rapids, MI
616.299.3654
Thanks rvalue.
People Online People Online: Visitors Visitors: 364 Members Members: 0 Total Total: 364
