ICF basement costs in Colorado
Last Post 07 Sep 2019 03:33 PM by Williambecker1. 24 Replies.
littlebossUser is Offline
16 Jan 2019 04:49 PM
Hi I am looking to build a 1600 sq ft basement in Colorado and looking at ICF vs a poured foundation as well as cost comparisons. I want a 9' tall ceiling height in the basement and probably 2" foam underneath a 4" slab as I plan to park my truck there. With ICF all I have to do is finish the inside and outside walls- probably stucco on the outside and sheetrock or OSB on the inside. If I go with a poured wall I could have the exterior foam added to the foundation but I would have to build a framed wall on the inside and then insulate that. Any comments on pricing between the two and which is the best? Thanks
BrucePolycreteUser is Offline
16 Jan 2019 05:29 PM
ICF should cost less. But for 1,440 sqft of wall, the total $'s difference will not amount to much. Something of that size, the decision should be driven by convenience. Why not do the whole house with ICF?
16 Jan 2019 06:12 PM
Posted By BrucePolycrete on 16 Jan 2019 05:29 PM
Probably going with a log home but want the ICF basement so I won't have to worry about the plumbing in the basement freezing
16 Jan 2019 06:46 PM
Tell your log home builder that you want an ICF basement and see what he says. If you plan to do it your self, go for the ICF as it will be easier with fewer tasks.
newbostonconstUser is Offline
17 Jan 2019 01:21 PM
I agree, if you are going ICF then go all the way to the roof. You have to cover the walls with some sort of fire block. OSB won't work for inspection. Drywall is the cheapest.
18 Jan 2019 06:55 AM
What is the cost ps/f for the ICF?
19 Jan 2019 03:35 PM
I was hoping someone could tell me
DilettanteUser is Offline
21 Jan 2019 05:47 AM
Thing is, ICF isn't really factored on "square footage" of the floorplan.
But on square footage of the wall structure itself. Height x Total Length of the wall with a non-specific increase for blocks yielding a concrete wall (without insulation) of more than six inches...
This is price of blocks, plus concrete costs to fill total cubic footage.
LyndajamesUser is Offline
24 Jan 2019 10:41 AM
What would be the cost for this?
25 Jan 2019 07:10 AM
'Thing is, ICF isn't really factored on "square footage" of the floorplan'. Who said that?????  People 'aren't' asking about the sf of the house. What is the cost for the 'exterior' sf wall????? Why is everybody here avoiding that??? Is this more marketing BS???
25 Jan 2019 06:08 PM
Budget $17,000. If you want a hard price, send a set of plans to a contractor and ask for a bid.
25 Jan 2019 11:08 PM
Posted By robinnc on 25 Jan 2019 07:10 AM
Did you actually read the rest of the post?
Or did you just read the first sentence and then blow up?
I said something fairly specific.
And you're having a conniption over one portion, while ignoring what was said in the rest of the post.
The overall-whole-system cost of ICF isn't simply factored by floorplan.
Things like wall height, wall thickness, insulation thickness, number of corners/rounds, type of concrete and additives, rebar schedule, etc can cause the price to vary wildly.
So please calm down.  Your attitude is unproductive.
26 Jan 2019 12:50 AM
Maybe because it is so variable no one wants to go out on a limb only to have it cut off! Block prices vary by manufacturer, by distance to be shipped, and ease or difficulty of getting them dropped at the work site. Concrete prices vary a lot, particularly state to state. Concrete laborers costs vary a lot. I'm going to guess based on past discussions here, and my own experience 10 years ago, you can figure on something like $10 to $20 per sq ft of wall.
26 Jan 2019 04:10 AM
1: Send plans to an ICF vendor and have them quote you for the exact type of block you're looking for (core width, insulation width, etc)
2: Figure out your rough cubic yardage. Then round UP to the nearest multiple of 8 cubic yards (a standard concrete mixer truck's size).
3: Take that to a concrete contractor, along with the type of concrete your engineer is telling you that you want and have them quote you for the concrete, the trucks and manpower to haul it, a pump truck and the crew to run it. Keep in mind this does NOT include a concrete foundation or concrete slab. Those are a separate cost, will need to be delivered at a different time and will also need to have mixers and a pump truck paid for.
4: If you're going for extra additives (like fiberglass filaments or Helix steel), factor THOSE in too.
5: Calculate out your rebar costs plus labor to cut, bend, place and tie. Factor this BEFORE deciding you're going to "just do it yourself", because that's a LOT of labor.
6: Factor in the cost of the bracing (if buying it all yourself). Or obtain a quote from an ICF installer for a crew.
7: Do a generous "back of the napkin" budget for screws, 1-by stock and plywood to reinforce the ICFs during the pour to prevent blowouts.
8: Obtain a quote for door and window bucks of the proper size. Talk with an ICF contractor about simply going with permanent steel bucks that are placed during assembly.
That's just PART of the process.
Hence the reason nobody is going to just spit out a quote for $X based on the small amount of info given.
Hence why people are being directed to speak to the experts in their area and provide them with the necessary information.
Because why would you go through the whole process on a random forum with an ICF contractor in FLORIDA if you're going to be building in COLORADO?
Are you going to fly said contractor and crew out and put them up in hotels for MONTHS? While they're ignoring their market back home?
26 Jan 2019 07:01 AM
dil and dm......I understand business. I have 3 degrees in business. But the OP is asking for a average cost of either 4" core or 6" core in Col. Several years ago people on here would actually answer this question but they don't seem to do that these days. Usually people here that ask questions can get the 'real' answers in their area of the country. To keep from getting ripped off.  IMO.....it sounds like the ICF are trying to rip people off. If I'm wrong....prove it. Marketing is taking over 'everything'......it's sickening!!!!!
OP.....contact the local ICF supplier in your area(not GC) and get their opinion.
26 Jan 2019 11:04 PM
Your three business degrees don't really mean much in the trades.
They're basically pieces of paper stating you know, in general, how do keep the books for any given business and structure the paperwork side of things.
The problem is, how many of us KNOW the average cost of ICF in the Colorado market?
How many of us know the cost of concrete in the Colorado market?
How many of us know the shipping costs and schedules in the Colorado market?
We have people who're down in Florida, up in the New England area, I'm in Chicago, and a couple people out on the West Coast (just pulling this off the top of my head).
Now, if we actually have someone in the Colorado area who's got the local info, GREAT!
If we don't, we're likely to advise you to talk to multiple ICF vendors and contractors in your area.
And if there are no ICF vendors in your immediate area, SHIPPING becomes a significant expense. Sure, the primo ICF product you WANT may be cost-competitive with a cheaper, but more basic product. But if the primo product is shipping from Georgia, and the basic product is shipping out of Indiana, you could see SIGNIFICANT cost variances.
It's not because people are trying to rip anyone off. It's because there are too many variables. And cost calculation IS NOT "marketing BS".
And, you realize that you just asked people here to prove a negative right?
Now, you evidently have a chip on your shoulder against ICF and "marketing".
Why? Nobody knows.
But nobody actually cares either.
Again, the way you approach this is needlessly aggro and unproductive.
Again, if you want general advice about HOW to go about getting pricing here, we can do that.
If you want someone to quote you a dollar amount out front? Forget it. Simply because the process is never that straightforward. And nobody here in the industry is going to be held up to ANYTHING but an EXTREMELY high-ball quote because of the general lack of information (Didn't do your homework and can't supply the info? Up goes the price. Because they have to account for the uncertainty factor.)
Finally, I will ask you once more to calm down. You're helping nothing with your attitude.
27 Jan 2019 07:00 AM
Dil, I understand business and building a house. I had just finished building a spec house, Frank Betz (The Middleton) when the great recession hit. I had planned on going into the business of building houses. I understand what you are saying. IMO....99% of people have no clue on ICF and there is verrrrrrrrrrrrry little competition to keep the prices 'competitive'. IMO, I think the GC's are taking advantage of this. The GC's need to add up what a customer could save going with ICF in building costs, lower HVAC(lower tonnage) installed price, includes insulation..lumber savings, and many more items.
I'm ALL for ICF for our next house.
27 Jan 2019 07:19 AM
Posted By robinnc on 26 Jan 2019 07:01 AM
You've been on this board about the same length of time as I have. I'm sure you have also noticed the very significant drop in traffic the past several years. Fewer people overall means fewer people from specific areas which means less sharing of knowledge for any particular area. I don't think there is a deliberate refusal to provide numbers. It's just that the ones who could give the OP meaningful numbers for his location in CO aren't active on this board.
BrullesUser is Offline
27 Jan 2019 03:47 PM
Foxblocks has distrubutors all over Colorado. Buildblock has a pricing and estimating section on their website. Nudura has the same type of resource. I'd suggest getting in contact with any one of those companies and let them give you an esitmate since they are going to be the most familiar with the costs for material and shipping to your site and the general cost of concrete and how much you'll need. Once you get that cost go to a GC and get an estimate for labor unless you want to do it yourself.
28 Jan 2019 06:59 AM
dm......you're right. I just REALLY like ICF and don't want GC's to rip people off. GC's make verrrrrrrrry good profit(I have no problem with that......that's business) (They lie thru thru their teeth and shouldn't open their &^$%##%%# mouths about profit when all they do is lie, without ripping people off. IMO....when people ask the stupid question on how much they make they should keep their &*&^%^$% mouths shut!!!!!  In the last 40 yrs I have had hundreds of GC's lie thru their teeth!!!!!!!!!!!!!!!!!
People Online People Online: Visitors Visitors: 225 Members Members: 0 Total Total: 225
