Posted By karp2005 on 26 Mar 2019 03:32 AM
Hi, I'm curious is there a section in codebook regarding of using icf? I have found something the same on web page of insulspan for their panels, but can not found it for buildblocks icf blocks. Basically, I'm interesting of thickness of cement core, how often I need to put rebars, and what minimum cement core should be on top of the windows opening.
Chapter 3 - Planning (Foam Plastics),
Chapter 4 - Foundation,
Chapter 6 - Wall,
probably others.
If you go to major ICF vendor's website there are many documents available for free download. There are design and install guidelines that have charts that show how to do prescriptive design of footings and walls. It is basically the same as what you will find for prescriptive design in the concrete foundation and wall sections of the building codes.
